M Mkuhn138 1/2 ton status Joined Mar 20, 2010 Posts 362 Reaction score 2 Location Carlsbad, CA Sep 28, 2012 #1 I've gotten d60 front torn down to the carrier and inner/outer shafts. The shafts will not slide out. Is there something I'm missing?
munepit 3/4 ton status GMOTM Winner Joined May 6, 2009 Posts 5,974 Reaction score 186 Location Bakersfield CA. Sep 28, 2012 #2 If you have it torn down that far, It should come out. It's a full floating axle. There are no C clips holding it in.
K85 Octane People Fatigued Premium GMOTM Winner Joined Nov 2, 2009 Posts 15,362 Reaction score 5,963 Location San Bernardino CA Sep 28, 2012 #3 there is either damage or your spindles are still on.
M Mkuhn138 1/2 ton status Joined Mar 20, 2010 Posts 362 Reaction score 2 Location Carlsbad, CA Sep 28, 2012 #4 The spindles are off. There was some corrosion when I took the cover off so I'm guessing that's the culprit. Any suggestions?
K85 Octane People Fatigued Premium GMOTM Winner Joined Nov 2, 2009 Posts 15,362 Reaction score 5,963 Location San Bernardino CA Sep 28, 2012 #5 big crowbar leveraged on the axle tube, end of it through the u-joint area, and "help" the axle come out.
