Dana 60 shaft removal
Mkuhn138
Carlsbad, CA
I've gotten d60 front torn down to the carrier and inner/outer shafts. The shafts will not slide out. Is there something I'm missing?
If you have it torn down that far, It should come out. It's a full floating axle. There are no C clips holding it in.
The spindles are off. There was some corrosion when I took the cover off so I'm guessing that's the culprit. Any suggestions?
big crowbar leveraged on the axle tube, end of it through the u-joint area, and "help" the axle come out.
