cut it off in chunks if you need to
That is exactly the plan.
FWIW, I welded my 14b spring perches on with a big 110v welder and it’s been fine.
I used a Porta bandsaw to cut my perches off in chunks. Then ground it down. A sawsall would be almost comparable but I'd think you'd need lotsa blades.That is the thing I am definitely mentally preparing for is the removing of the spring perch. That is going to be a b!tch. I have an angle grinder with plenty of cut off wheels and 40-grit flap disks to get that sucker off and down to flat clean metal.
I was blaming it on the extra weight on that side from the spare, or damage from when my rear axle came loose... but I just went out and measured and sure enough, I didn't put enough shim in there. The height from axle to top of plate is 0.5-075" shorter on the driver's side. Now I need to figure out what to do. The right thing would be to remove and replace the perch, but I'm not sure I trust myself to get that right myself... I think shoving a bigger shim/easy-inch in there might be excessive though. Or I live with it.Not to hijack or anything, but this thread got me thinking about my setup. When I first got the D60, the perch was tweaked and I had the perch replaced. The guy messed up and used a normal perch though, which I quickly discovered when installing the axle. I asked Kert at DIY4x to make me a custom shim with lift in it as you can see in the picture. Time passed and I noticed that the truck seemed to lean a little bit to the driver's side. I never put 2 and 2 together until just now!I was blaming it on the extra weight on that side from the spare, or damage from when my rear axle came loose... but I just went out and measured and sure enough, I didn't put enough shim in there. The height from axle to top of plate is 0.5-075" shorter on the driver's side. Now I need to figure out what to do. The right thing would be to remove and replace the perch, but I'm not sure I trust myself to get that right myself... I think shoving a bigger shim/easy-inch in there might be excessive though. Or I live with it.
When I do the spring perch replacement before I cut it off I am going to take all the measurements, and one of the measurements is going to be the height of the spring perch so I it will be welded back on at the same height.
