dana 60 steering block...and parts etc
rob h
frackville,pa
parts listed are sold as of 2-9-09...sorry... have a dana 60 superlift steering block with studs , goes under stock 60 arm ...4inches high with spacer for spring used 1 year....50.00 obo...(for draglink correction was 100.00 new).... , drop pitman arm for 4wd steering box...i think its a 4inch drop (which they dont make anymore)... 25.00...obo.. and superlift drop brackets for stabilizer (for 4-8 inch lift).........stock 60 steering arm 20.00......
parts cheaper....
dana 60 block and studs..40. , the swaybar drop barckets 20. , the pitman 20. ...............
the pitman is sold....sorry.., sold it went last night.............. left are the d60 block and studs and the swaybar drop bracket..................also have the stock 60 steering arm...
anyone need the swaybar drop brackets 20.00 , stock dana 60 steering arm 30.00 or the block and studs to raise the stock steering arm 35.00...?
block and studs are sold.........just the swaybar drop brackets and stock d60 steering arm
ill get those tomarrow, they are superlift brackets ..its like a piece of channel cut in half and half mounts to each side...
sway bar drop brackets
pics of brackets, also have the bolts.....
