Mkuhn138
Just put my 35 spline stub shafts on and am having some difficulty. 1 of the C clips on each shaft/ujoint will not snap in - basically the cap on the ujoint needs to press on a few more thousands for the clip to slip in. I have tried everything short of using a press and have had no luck. Was thinking about sanding or grinding down the C-clips just enough so that they slide into the grooves. Before I do that does anybody have any suggestions???
