Dana 60 stub axle ujoint C-clip issues
Mkuhn138
Carlsbad, CA
Just put my 35 spline stub shafts on and am having some difficulty. 1 of the C clips on each shaft/ujoint will not snap in - basically the cap on the ujoint needs to press on a few more thousands for the clip to slip in. I have tried everything short of using a press and have had no luck. Was thinking about sanding or grinding down the C-clips just enough so that they slide into the grooves. Before I do that does anybody have any suggestions???
Did you try hitting the yoke "apart" with the hammer?
Martin
No, you have th clamp the shaft in a vice, and then you have to beat on the inside of the yoke, to spread it apart. Do it ll the time. It can be a trick with the other shaft in the way.
Martin
Anybody know where to get replacement C-clips. One flew off when I was removing it and now I can't find it....
could give you one . got to check out the ones i have . i have a LOT of them . but got to make sure i got a 60 stub joint one tho.
