Modblacksmith
I'm starting a new project and I'm concerned about if the D60 will hold up to the weight of the engine I'm swapping in.
The project- I want to put a 1500lb engine that holds 30 quarts of oil in a 84 Chevy dually with 8 to 10 lug adapters, 22.5's and 40 inch rubber. Also there will be a heavy custom bumper on the front.
I've done a little research on this and found that the 60 is rated for 4500lbs, but I didn't find anything on if it differs from the srw to the drw axles. I'm considering trussing the axle right from the start too.
Is it going to eat bearings cause all the weight is so far out on the end of the hub?
Are the king pins and bearings in the knuckles going to hold up?
