buff_dog70
Put a Dana 60 under the front of my 82 diesel Jimmy. Went out wheeling, bent the front drag link? (links knuckle to knuckle). The death wobble started and it was bad. Rebuilt kingpins top and bottom, and replaced bent drag link with a new ORD drag link, and new ball joints. Tried to set alignment 1/4 inch to 1/8 inch toe in, by using a tape and going off the brake rotors. Wobble decreased but did not go away. Finally took to have the alignment done at a shop. Seems worse now. I running 35 inch tires, old junky ones, one is not a match and the tread is seperating. Also the ball joints on the tie rod are old, OEM. I also have the steering stabilzer hooked up, but the OEM bolt bushing fits loosely. I don't think the frame is cracked around the steering box. I thought the rebuilding lingpins and fixing the drag link was going to solve the problem. I was going to try fix the steering stablilzer bushing. Maybe balance the tires. Any thoughts or trouble shooting to try would be greatly appreciated.
