KidJethro said:D70HD ring gear is 10.54". 14B is 10.5".
D70HD tube is huge...way bigger than a 14B. 4"
A D70HD shaft is 1.5" 35 spline. 14B is 1.5" 30 spline, however, the pressure angle of the splines on the 14b is different than most any other, which makes up for the 5 spline advantage the 70HD has over the 14B.
A 14B tube is 1/4" thick. All dana axles are atleast 3/8".
This is one area where BillaVista's 14B bible is incorrect. It lists the 14B as having .5" thick tubes. If it did, they would be ungodly heavy.![]()
If what you posted is accurate, there is some serious misconceptions in the wheeling world on this subject. Front Dana 60's still have .500" wall tubes right? Can anyone else confirm that FF 14 bolts only have .250" wall tubes?
It just seems that this would have been brought to light a long time ago if the wall thickness was that small. I imagine that there have been tons of people that have narrowed 14 bolts over the years and I would think they would have mentioned the thin tubes on pirate or here. It's a pretty major thing, for it to be unmentioned (at least from everything I have seen) would really surprise me.
I have no doubt that the axle you cut was .250", I just question whether that is how all 14 bolts are
