dana axle case spreader kit deal
sweetk30
Back to play nice .
in the back of your brain
i was looking for a deal on a used case spreader. well lots of here but gone or none to be had on lots of chat forums.
so i went to ebay. found lots of new name brand. but found ebay seller ( aabad ) he custom makes these and has super feedback. same kind of good working tool as name brand. but 100x the beef of name brand.
this thing showed uptoday in a nice wraped/sealed/packed box. the ship tag showed 34 lbs :eek1: dam this thing was a tank in the box. the rest of them on name brand are under 20 lbs :(
if you plan on doing a few sets of gears on dana axles a year and or just love kick a$$ tools to add to your tool box then this is the one for you.
oh ya did i mention his price shipped was just over $220.00 . the rest of the name brand was $425-$450 range just for tool .
o.k. here is the pic of the unit. and i need to work out more after picking this thing up. :1zhelp:
left and right side of diff has a big pin hole. you screw in 1 pin per side. ( shinny screws in pic ) then get snug by hand.
when ready you turn the main nut and measure from 1 main bearing cap to other and streach no more than .015" max. most say .007-.010" average spread.
this lets you pull the carrier out easy. then when setting up new gears and bearings you can set propor preload on new bearings when all set.
just a new big fun toy to play with . :D
Cool, I'm sold, I want one :D
Scored one at a swap meet years back for $35.00. Good heavy duty one still going strong today. Not that it gets used that terrible much.
While a case spreader does make the job easier the job can still be done without one. For me I would never spend that kind of coin on a case spreader even if I did several a year.
Looks easy enough to just burn one up actually. sweetk30, ya willin to give dims on this so others can make one if necessary?
go search pirate. its over there.
and i dont have the time/ means / avalibility of steel to build it. so thats why i purchased one.
How the heck does that thing work?
Here's a pic of one in use.
Gus
Nice looking unit there. I got a Kent Moore unit a few years ago for about a hundred bucks.
Case spreaders definitely make the job easier, especially when doing it on stands like the pic above, but keep in mind that they can not be used on a front axle when the axle is in the truck.
I was going to use/ borrow one on my 60 front, but It meant pulling the housing out of the vehicle or pull the leaf spring, because the leaf spring was in the way, I decided to not use it after all... on a rear axle it would be killer, but I have a 14 bolt...
