Rear??
Yes, for a dually.
Rear??
Hell Yes Brother ~ My first goal it to clean re-re-pack/grease and DRIVE!! I am a bit concerned about my ability to get the seal out without foobaring the snap out of it!! I suck at feee-ness!! Plus they be stuck good << aka rusted ! so I ASSume I will need fresh sealsi JUST did front rotors on my 60 front . its now under truck #4 with the same bearings and races . and last time apart was almost 20 years ago . its done plow truck / mud truck / daily driver / and more duty . i just cleaned out the dead grease and checked the parts and all they needed was a re-pack with fresh wheel bearing grease and seals.
take this info and roll with it . and i live in the north east RUST belt of hell !
I still need to get Part #s if my cleaning of the bearings reveals more damage, then I will be forced to start over with new parts...Any idea why my D60 front would have 6pt wheel bearing nuts?Yes, for a dually.
ShoeeWee.. Guess I'm going full in! This shit is contaminated big time!Id get new spindle bearings and seals while your there...
OK..... So I have rear axle hardware on my D60 Front ! OK then..... I already have the 6pt socket... so,,,do you think I need to consider swapping to front hardware.... or its all the same shit anywayImo, it looks like you have rear axle hardware on you D60. That is the exact same set up on my D70HD and my old 14 bolt.
Edit: same spindle size so no big deal.
Problem is I'm more "corroded" than most situations... but thanks for the tip anyhoo!To pull the hub seal out: remove the spindle nuts and outer wheel bearing, put a spindle nut back on a few threads. Grab the rotor and pull off the entire hub assembly off the spindle.
HellYeah... well I have a 14FF w/disk rear so not sure if the socket will do it any good but hey!!Keep it the way it is...one socket does front and rear
In the morning me try.... too much whiskey tonight lol...It will work, the hub acts like a slide hammer, the seal and inner bearing come right out.
told you early style got these . then 1980-1981 ish up got 4 tab .Any idea why my D60 front would have 6pt wheel bearing nuts?
