Well we went back to Ohio to visit family from the 15-25th. Obviously no progress was made during that time (woulda been sweet if I got back and some of this crap was done though
). So I was a lazy a$$ Wednesday, and ended up working Thurs & Fri, plus I will work this whole week and next. Apparently there was a scheduling conflict and I figured I could use some $$$
Anyways, Saturday I finished up the door latches. I realized about 3 hours into the flight to Ohio that I never checked to see if the window channel would work where I mounted everything
Luckily everything fit, I just needed to trim a bit off the tab I made and drill a new hole
So after screwing around with that for a bit I then decided to tackle the passenger door alignment woes. After loosening and tightening the hinges about 10 times I finally got it to where I'm good with it. A few love taps with a hammer and dolly and it'll look great. Either way the door opens and closes like a dream now. The days of having to man handle it to let the wife in and out are over
What's funny is the door alignment/ PITA was the original reason I started taking this thing apart. Can you say Might as Well's????
Then I patched the holes that I found full of bondo in the upper rear quarters where the PO had some ghetto-billy dual antennas or something...
Next up should be stripping the rest of the rear quarters and hope to not find any more GIANT "accumulations" of bondo. Then I'll sand/prep the inner rear panels. I should be spreading and sanding appropriately thin coats of filler by this weekend
Then I plan to push it out of the garage and give it a good blow-job, err clean out
and I'll start to rig my "paint booth". I may just spray the interior/jambs for now. The neighbors across the street moved and I'm pretty sure their landlord is the a-hole who tattled on me last time so I may have to wait to do the booth until the new tenants are in. I want to do the inner/outer firewall now though so I can mount the MC's, pedals and run the wiring harness before I put the front clip on for good. We'll see how that goes.
On to the couple pics I took.
