mr_blasto
I have a motor with dart heads and figured I would consult their website for spark plug recommendations. According to them, I need to be using one of two autolite plugs AR3933 or AR3934, both of which are racing plugs.
The problem is Autozone doesn't seem to have them. They can't order them either and they don't cross reference to a plug they carry.
These plugs are available from summit, but I am hoping to find a local solution. The plugs have:
.750 inch reach (regular plugs seem to be .708)
Don't have a resistor (normal plugs do)
14mm threads (pretty standard)
gasketed seat (most seem to be tapered)
5/8 inch hex (pretty standard, but I found a delco plug that almost worked, except for the 13/16 inch hex).
Anyone else run into a similar problem? The autolite catalog says these plugs are for racing bbc's, hemi's, and porsche's (IIRC). But I looked up a non-racing plug for a bbc and it showed one with a tapered seat, .708 inch reach, and was a resistor type plug. I am so confused, someone straighten me out
. BTW, I don't have a stereo of any sort so a non-resistor plug shouldn't be an issue.
