I am new to posting so bear with me. I hope my pics come out okay and in the order I want them to.
Like many of you, my dash was in need of some help. My bulbs were burned out, my gauges could not be seen at night, and frankly I was sick of looking at it the way it was. I decided to take it all apart and finish replacing the gauges. I had already wired in, a few months prior, a tranny temp gauge and decided to do the rest.
The job I would label as very easy. It required some #2 Philips, a 1/4" socket, and I believed it was a 6mm socket.
This does require one to take out the gauge assembly. I am not going to cover that. It is pretty easy to figure out.
The first Pic shows how I had originally mounted the trans temp gauge. I had taken out the dash, dremeled out the back, used a die grinder to slightly enlarge the hole in the black metal bezel, attached the gauge to the bezel, cut out the clear plastic in front of the trans gauge, and put it all back together.
I used yellow wire for my sender, black for ground, red for Ign power.
I found a nice ground block on the brake pedal assembly which I used for all my grounds. I crimped all the connectors and used electrical tape.
The second pic was just for my reference but shows the holes for the lights behind the gauges.
3rd pic shows the gauge cluster with all the gauges removed. Now it starts to get interesting.
4th pic shows the gauge cluster out with all the gauges removed. It requires unclipping the stock wire harness in the back and also unclipping the speedo cable. Pretty easy straightforward stuff.
5th pic shows the stock printed circuit. Looks daunting but it isn't.
