Ok, I bought a K5 with a '79 350 in it. Pulled the motor yesterday and did a compression test tonight with a screw in tester. Did a dry test and I got reading from 27 lbs to 30 lbs depending on which cylinder that I tested.
27 lbs and runs? Don't smoke, seems to be strong but doesn't crack the throttle either, but it is a '79 so what 8.5 to 1? Starts easy? Yes. Has anyone had a bad tester before? I have had the tester for years, but it looks absolutely perfect. What the hell am I doing wrong?
I am about to put it into a '87 K5, but didn't want to do that if it is ****. Ok, maybe a bad valve, but all cylinders?
