Help me decide which direction I want to go.
I have a 2wd 4l80e that I got with my 6.0. I have the adapter to mate to my 241(mechanical speedo), and I also lucked out and have the long splines output shaft. Mileage is a bit of a mystery so a rebuild is most likely going to be needed ($1400). The good thing about the 2wd is the speedo is located on the trans, I won't have to fool around with any VSS stuff.
BUT
I have to change the 241 input to 32 spline and move my crossmember. And now I'm just thinking about size, weight and parasitic loss associated with the 80.
OR
I can buy a "new" rebuilt 4l65e for $1750 (heavy duty) or $2500 (extreme duty) and includes a trans cooler and a Hayden cooking pan. Bolts right to my transfer case, no moving of the crossmember, but I have to go through trying to find VSS.
BUT
OR
