Colttan
Registered Member
Where can I find a good deep cycle battery that can be sourced at a common local retailer? No yellow top optima, but something I wouldn't have a hard time warranting out on a road trip or something.
I had thought about that but a shop foreman buddy of mine had said something on time about marine battery's aren't a good idea in a car or truck, something about them only lasting 6 months or so. Has anybody ever heard of that being true?
A true deep cycle won't last too long in your car.
Better to get a solid quality normal battery
OK, the lines between deep cycle and regular batteries have blurred a lot in the past few years. And a lot of the stuff I used to write about the differences is a little outdated.
The main problem, is that a true deep-cycle battery is not designed to produce high currents. Doing so will cause physical damage to the battery.
However, regular batteries will be damaged by deep discharging.
So, what to do?
Well, there are a lot of "hybrid" batteries out there now, mainly in the marine area that will do fairly well with deep discharging, but can still supply the current necessary for cranking.
If you plan on doing a lot of accessory use with the engine off, then you are on the right track with the dual batteries. There is no reason a marine deep cycle battery will not have a good long life in a truck, if you only use it for non cranking use. Its almost always the high current drain from cranking that kills them.
Friend of mine put a large deep cycle in his diesel tractor, and it burned up in less than a week. Charging system was working fine, but cranking that big diesel engine just warped the battery's innards.
Way back in 1979, I split the electrical system in my new Ford truck, using a diode isolator. I had one battery that only cranked the truck, while the other one ran everything else.
I never put a deep cycle on the other side, but I could have. Instead I went with a very high capacity truck battery. I did that, because I added a second starter solenoid with big cables running between the two batteries.
That way, I could jump myself off from inside the cab.
I don't think I ever had to use it, but I did use the accessory battery to jump others off a few times, just because it was on the best side for the occasion.
So, while normally a deep cycle would not last in your truck, it might do well if you do not try to crank with it.
Thanks for the info guys. I was running dual yellow top otimas in my k5 and both my batteries and the way I had them hooked up worked perfect and never let me down, one lived for 6 years and the other lasted about 4. But have since then havnt seen one last more than 3.5 years...but the biggest reason for this conversation is I'm not about to spend $450 on a pair of batteries on my new build
