defroster
stanley
Registered Member
cincinnati,ohio
is it o.k. to only hook up the heater vacuum hose and the egr to the vacuum pump by themselves? that's the only way i can get defrost.:confused:
For the heater that should be fine for winter time since you are just bypassing a bad switch.
I don't know what the EGR would do with direct vacuum though, did you hook up before or after the regulator or the Throttle position sensor on the pump
thanks for the input. it should be o.k. i usually go to quick search before i post so i don't seem so stupid
