Degree shim installation question
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
So yesterday @cheavyk10 and I worked on my truck and we came to the conclusion that my Rear axle needed 6 degree shims and the only ones we could find locally were some from 4 wheels parts. The question is how do we install them? Between the zero rate or under it on the axle mounting pad. The holes seem really large so we're not sure. Any suggestions would be helpful.
I would put them on the axle pad, the large holes are for the people that stick them under the spring pin and just use the u bolts to hold them in, I always like them to be actually bolted to the spring pack.
I think I want to go that route also. We didn't end up using these.
The only way I would want to run those is between your easy inch and the spring pack so at least it could be bolted in place. I would never even drive a truck if the center pin wasn't engaged in the perch.
Yeah those shims are so thick the pin would not engage The perch. And the hole is so big that the pinhead would not even hold it to the spring pack
Bolt the shims to the bottom of the zero rate.
Steel shims and new center pins can be sourced through WFO (see link below). Buy extra center pins and keep them in your truck if you plan on wheeling it.
Naa no wheeling gonna happen here
