GonicGM
For 1985 fullsize K30 Chevy Pickup, Looking for the following:
LF Door in Code 72 Apple Red(any 77-91 old style)
Tall tan kick panel(any 81-87 old style) drivers side, needs to be non A/C.
Tan door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic
Tan door panel pull straps and map pockets (81-87 old style)
Tan OEM Floor mats (81-87 old style)
Tan passenger side visor with mirror (81-87 old style)
13x2.5 rear brake drum(s) for 14 bolt FF 10.5 rear, clean
Clean pair (or individuals) of rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
SRW K30 OEM front hubcaps
Red glovebox(cover), mint, factory paint(any 73-91 old style)
85-87 dash bezel with Aluminum, non-A/C
OEM grey cardboard liner, behind seat.
RH front door power lock harness.
Dual tank harnesses, RH lines(any 81-91 old style)
OEM working HI and Lo tone horns (any 81-91 old style)
OEM 30 Series Tailgate lights and harness, complete or any small piece.
Camper Special stuff, Tie downs, dual battery harness & relay(73-91 old style)
Warn/OEM manual locking hub caps, Dana 60, 3/4 turn, fairly clean.
Clean OEM 8 lug white rims, Suburban spares ideal.
85-88 factory dual exhaust, any pieces, from carbureted truck.
85-91 NP205-TH400 Adapter, round pattern
Front bumper black plastic lower spoiler/air dam/air deflector.
Frame mounted receiver trailer hitch.
Silverado 30 fender emblems with studs in tact
Scottsdale 30 fender emblems with studs in tact
Factory Under bed exhaust heat shields
Non-A/C heater blower motor housing, engine bay side, steel, clean.
Passenger 8' bedside with fuel filler door, 81-87
Firewall insulator from 6.2 Diesel Truck(81-91 old style)
Door Jamb rubber seals from 6.2 Diesel Truck(81-91 old style)
Rear spring shackles from 1973 (folded with two rivets)
