Delete Please, Reposted, 73-87(91) Parts Wanted
GonicGM
Seacoast New Hampshire
For 1985 fullsize K30 Chevy Pickup, Looking for the following:
LF Door in Code 72 Apple Red(any 77-91 old style)
Tall tan kick panel(any 81-87 old style) drivers side, needs to be non A/C.
Tan door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic
Tan door panel pull straps and map pockets (81-87 old style)
Tan OEM Floor mats (81-87 old style)
Tan passenger side visor with mirror (81-87 old style)
13x2.5 rear brake drum(s) for 14 bolt FF 10.5 rear, clean
Clean pair (or individuals) of rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
SRW K30 OEM front hubcaps
Red glovebox(cover), mint, factory paint(any 73-91 old style)
85-87 dash bezel with Aluminum, non-A/C
OEM grey cardboard liner, behind seat.
RH front door power lock harness.
Dual tank harnesses, RH lines(any 81-91 old style)
OEM working HI and Lo tone horns (any 81-91 old style)
OEM 30 Series Tailgate lights and harness, complete or any small piece.
Camper Special stuff, Tie downs, dual battery harness & relay(73-91 old style)
Warn/OEM manual locking hub caps, Dana 60, 3/4 turn, fairly clean.
Clean OEM 8 lug white rims, Suburban spares ideal.
85-88 factory dual exhaust, any pieces, from carbureted truck.
85-91 NP205-TH400 Adapter, round pattern
Front bumper black plastic lower spoiler/air dam/air deflector.
Frame mounted receiver trailer hitch.
Silverado 30 fender emblems with studs in tact
Scottsdale 30 fender emblems with studs in tact
Factory Under bed exhaust heat shields
Non-A/C heater blower motor housing, engine bay side, steel, clean.
Passenger 8' bedside with fuel filler door, 81-87
Firewall insulator from 6.2 Diesel Truck(81-91 old style)
Door Jamb rubber seals from 6.2 Diesel Truck(81-91 old style)
Rear spring shackles from 1973 (folded with two rivets)
I have a lot of the stuff you need, but shipping will be the problem.
I would have been able to get them to MA if I had my ducks in a row, but now I am stuck here with an expired registration so another couple of weeks before I can move to CO where POORBOY is leaving to MA.
If you have a way to get them Cheap to NH let me know, lots of rust free parts that match your requirements.
I have some nice tan interior for sale but with bucket seats & power windows. I also have some rust free body parts but not in your color.
Power lock harness, doors and cross dash w/relay.
I will have to check what I have left of my '83 K20 in the garage. I used to have these parts, but I don't always remember when I sell stuff until I go looking for it.
I have a nearly complete dual tank transfer switch harness off of my old '83 K20. Only one wire cut, the connector was cut off at the firewall mounted junction block. I could not find the dash mounted switch or in cab portion of the harness for some reason... it is out there somewhere, just got separated from the rest of the harness.
I also have the complete under dash harness from the same truck, but I modified the P/W wiring for use with Freightliner switches mounted in the center of the dash.
$25 shipped for the complete harness if I find the in dash portion. I just won't have time to look closer until this weekend.
hub caps
i think the hub caps i have are what you're looking for ,send me a pm with your e- mail, & ill send you a pic of the hub caps
Keep me posted. I would have interest in a PW/PL harness (3 pieces) even with modified PW harness because I am only using the PL portion anyway.
The PL portion I do have with no mods. I don't think I kept the door wiring, but I have the cab portion.
I'm interested in the dual tank and dash PW/PL. Did you find the dash mounted switch or in cab portion of the harness?
Not yet, I cleaned up my garage a little but haven't been able to go through all the wiring harnesses yet. I have two weeks to go for winter quarter then I will be able to dig for the remainder. I work full time and have been taking night classes on top of it so my free time is limited.
Theres a 86 k20 with most emission items still intact (last time I looked) at my local salvage
I'd primarily be interested in an OEM molded rubber hose elbow for the LH (drivers) manifold A.I.R. check valve and the large black steel crossover pipe as shown in image, beginning of thread.
EFE (heat riser) vacuum can if not rotted off like most and the steel vacuum pipe to it with valve cover clips.
Any chance you could image under hood of this 86 K20?
Fairly certain those identical parts are still available and intact. I'll get down there tomorrow if I can
I'll be headed there shortly. Give me a call or text ASAP so I can conform these are still there, correct, secure them and make a deal if you want. 413-522-6764
