I'm not around enough to carry this post I guess so delete it....
Modded Body sold (JeremyK5)
New tan racing buckets with slides - $250pr
Tan center console, factory console - $40 (275 with buckets)
Tan lap belts and rear bench belts (factory stuff) - $40 ($300 for buckets, console and belts)
LikeNew 88 K5 Frame with mods, custom engine crossmember, 52" front springs custom hangers and relocated shackles, longer shackles, 56" rear springs with the original echobit flip and fabtech shackles, reman 2wd box with boxed frame, custom rear bumper and rear shock crossmember - $500
add up the parts this is a STEAL!
Frame was stored for 16 years in a barn, blazer had a dash fire in 88-89, it was in the barn till they parted it and I brought the frame home a couple years ago. Probley less than 10K miles, its LIKE NEW!
Used 2wd steering box, O-Ring type, with steering shaft and good rag joint - $55
31 gallon TBI fuel tank, good sender and pump, with braided lead lines filler and vent tubes - $150
31 gallon fuel tank unknown sender condition (non-TBI), needs tank washed out, filler and vent tubes included - $50
Extra front clip 87 Quad headlights (hood, rad support, GM fenders and inners, grill and headlight buckets) no rust on fenders - $250 - pending (rugger)
H1 rims and tires - sold Kert
Dana60 - Sold to Phils buddy
4 core radiator, needs cleaned up and checked - $25
3 core radiator, in nice shape-SOLD MARK
Extended/Long drive shaft for 208 to 10b on 6"+ lift - $125
(I have a 4" lift with zerorates and it was too long)
TBI 350/700r4 - sold Phil
(set of 4) little to no tread -roller tires- 31x10.5x15 Wrangler AT/S on clean 6 lug rallies with beauty rings and center caps - $75
2 seats available
(this is how the frame sits currently ^^^^^, no rear 14bolt as seen in photos below)
BRAND NEW REMAN BOX!!!! included with the frame!
I will include the upper shock bolts also.
MORE INFO
MORE INFO
Floor Rebuild Page
http://coloradok5.com/forums/showthread.php?t=102779
Custom Front Spring Hangers for Project Rusty Bucket http://coloradok5.com/forums/showthread.php?t=110240
http://coloradok5.com/forums/showthread.php?t=110011
http://coloradok5.com/forums/showthread.php?t=113747
Part Two of the front spring hangers
http://coloradok5.com/forums/showthread.php?t=110545
Engine Crossmember
http://coloradok5.com/forums/showthread.php?t=116415
CHECKOUT some other frame mods <<---- this is the newest link of the frame
http://coloradok5.com/forums/showthread.php?t=175262
Engine Crossmember
$1500 for 2 Steering rock's with pinion brake's , and a rear steer valve.
