The other day while repairing the fuel injector return line hoses,I noticed the oil cooler hoses/lines on my engine were oozing oil where the rubber portion is crimped to steel tubing ,that comes out of the block...I knew the tubing was getting flaky and thin,and for some time I've been expecting them to fail and spray oil everywhere (and hopefully I'd see it and shut it off soon enough to prevent severe engine damage)--but I didn't expect to see the aluminum "crimp collars" were completely corroded away on the bottom side you cant see easily!--one had popped open,it was a miracle the hoses didn't just blow right off the tubing!
.................................................................................................I ended up using a sawsall to slice off the tubing at the block ,after trying to unscrew one of them and twisting it into macaroni about 10 turns before it finally broke off,the tubing was still pretty thick there,but thin and ready to pop near the exhaust manifold....................................................I put two 3/8" NPT pipe plugs in the holes in the block,after removing the adapters GM used for the OEM hoses (which are special I guess,the hose tubing has a flat shoulder instead of a flare,and the tube protrudes into the adapter fitting ,which has a plastic sleeve inside of it...I saved them because new ones cost 25 bucks and are hard to find,in case I ever replace the cooler lines)....................................................................................................The engine now seems to have slightly higher oil pressure,and the gauge does not vibrate the needle wildly as much as it used too....I doubt I'll ever put new hoses on it or an aftermarket oil cooler,I dont use the truck much and not for towing in hot weather,I dont think it really needs an oil cooler......now,if I could only replace the rotted oil pan,maybe I could save 10 bucks on oil every time I go to use it!.......................................................................................................So far I think I fixed what I thought was a leaky fuel injector by replacing the rubber "cap" that blocks off the "extra" return line nipple with some tygon fuel line with 1/8" I.D. and using a machine screw to block the other end of it,and I also used a peice of that hose from the injector next to the one that had the drippage (furthest one back on the drivers side,hardest one to get at of course!
...)--ran it about ten minutes after douching everything with brake cleaner,and I didn't see any dripping,I hope it stays dry until spring..the injector line going to that injector looks VERY thin and rotten though,especially where in enters the cap nut at the injector...if it seeps a little I wont care,as long as its not dripping steady like it was......................the tygon hose needs no clamps ,and it would be impossible to install one on that injector without removing it--got the hose at a small engine shop,they use it on chain saws and weedeaters.........................................................................................I would reccomend anyone who has a truck with a factory oil cooler to inspect the hoses GOOD,before one fails and empties the crankcase,its a very common failure prone part on many GM trucks...gas engines as well as diesels have them now,even V6 ones,and I've seen many trucks spin a bearing thanks to the hoses failing......
