Sold Deleted
looking for a flywheel cover thanks
I just saw your other post, they are called flexplate inspection covers on automatic transmissions since there is no Flywheel.
I have one still on a TH350. $25 plus shipping and it will fit your truck. I will also include mounting hardware.
Hello, looking for a couple pieces of hardware for a Sub with barn doors. Missing door latch (?) and a limit strap pin. Do you have either? Shipped to 19956. Thanks
I should have both in good condition. Let me dig them out and get pics. $25 shipped.
Hello. I’m working on an ‘88 k5 Jimmy and looking for steering column, skid plates, ashtray, front driveshaft slip yoke, and the support bar that connects the transfer case to the transmission bell housing. You have any of that?
I will need a pic of your transmission crossmember to get you the right skid plate but I have those for $75. Tcase to bellhousing brace for 700R4 $25. I have several ashtrays, FREE.
I do not currently have a steering column or driveshaft parts you need.
I’m 20 minutes away from it, so here’s some pics I had in my phone. It now has a 4l80e and the spacer things above the crossmember were put back where they belong. I figure we’ll have to do some modifying to that brace I’m planning to buy from you.
Am I missing something else under there? I only have the crossmember in the pic and the gas tank skid plate. And def gonna do some rock crawling.
I also remembered an interior piece - do you have the passenger A pillar cover in gray? Oh, and thanks for the ashtray!
That is the S crossmember and I have one skid plate for that style. The 700R4 brace is shorter than the 4L80E version. It would probably be cheaper to find one closer than ship the one I have. The skid plate and ash tray would be $100 shipped in a flat rate box. I'll need your zip code to check shipping on the brace.
Sounds good. But please do let me know shipping on the brace. I doubt it’ll be a dealbreaker.
78537
