Well I was attempting a decent rock climb, the back tires were down in a hole and I used the skinny pedal to try and drive it out and up, the truck took a big hop and bang!! The rear drive and yoke became a mangled mess. Thankfully the front drive shaft stayed intact and I got tow strapped out to the forest service road before driving it home in FWD..
After examining the mess it appears the axle wrap was causing the pinion guard to contact the drive shaft and then the big hop and power caused it to dig in and the rest is history..
So aside from fixing the broken stuff do you guys have any recommendations for anti wrap? Seems like there’s quite a few way to address it, I’m hoping for a relatively inexpensive option that doesn’t require welding and won’t limit suspension travel..
Also reading the 14 bolt bible seems like I should convert the rear pinion yoke to the U bolt style yoke vs the strap style. Is it possible to just remove the nut and replace the yoke? I really don’t want to take the diff apart..
