Thanks 4x4high, it's running now!
So, I'm driving on the highway, the blazer begins to back fire and sputter. No power when you hit the gas but will keep moving slowly at idle.
I pulled over and the engine shut off. I can't get it started since.
Fuel pump is running and getting gas to the fuel filter; 4.5 psi fuel pressure. Checking the wires, I get a spark with a tester set on a tight gap but not a larger gap. Compression shows 150 on the 4 cylinder I tested.
I replaced the plugs and wires; some of the wire boots were melted to the headers and the plugs looked normal.
For some reason, the battery ground wire is hot. What could cause that?
Any idea what I should test next?
Timing- any chance the timing chain can jump?
Compression- check all cylinders?
Electronics- hei coil, cap or rotor? How can I test this further
Carb- qjet seems like it squirts gas when you open the throttle?
