Kinda off topic a bit, but is the 14ff (10.5") still in production today for any use case by any manufacture?
Yes in 6.0 2500HD pickups and 3500 suburbans.
Yep sure are. Diesel trucks got the AAM 11.5” tears so the 14FF’s are still going strong.Kinda off topic a bit, but is the 14ff (10.5") still in production today for any use case by any manufacture?
Was the gas truck a crew cab? If so then that's normal for crew cabs to come in 2500's, or 3/4 tons, and still use the same frame and axles as a 1 ton uses. Just the springs made them different.
Correct ^^^^^^^Technically they are 10.5" AAM (American Axle and Manufacturing). AAM is a spin-off of the old GM Corporate axle division. The 10.5" used in many newer 2500HD's is basically the same axle as the 14FF with a few updates.
170 mm bolt pattern as in the same as the Fords? If that's the case then I can find Weld Racing wheels all day long with that pattern. Just need to address the pattern issue up front on a solid axle.The 2011 and newer 10.5” and 11.5” in pickups have a 170mm bolt pattern and 4” axle tubes. The van and suburbans 2011 and newer have the 4” axle tubes and a 6.5” bolt pattern. Those are the most desirable ones.
If you go off road with a 11.5 aam unit you have an even bigger anchor than a 10.5 14b. Don't get me wrong, it's a great axle for brute strength towing, but it's huge size in the housing will kill ground clearance.Correct ^^^^^^^
If anyone can find the next best thing get the 11.5" rear 14 bolt. These things are MASSIVE! I used to get hard seeing and handling a D70HD (still do, in a way) but these 11.5's are huge! Plenty of them out there and in SRW configuration plus most of them have disc brakes so you're already ahead of the game with a swap.
No. I hit the wrong key. 180mm not 170mm(Ford).170 mm bolt pattern as in the same as the Fords? If that's the case then I can find Weld Racing wheels all day long with that pattern. Just need to address the pattern issue up front on a solid axle.
I'm aware of the design and pinion and also the size. In my area the size won't matter since we don't have rocks around here. I'm perfectly fine with the pumpkin as it's not much different than a 14FF.If you go off road with a 11.5 aam unit you have an even bigger anchor than a 10.5 14b. Don't get me wrong, it's a great axle for brute strength towing, but it's huge size in the housing will kill ground clearance.
One other thing about the 11.5 is the pinion gear and bearings are not in a separate pinion housing like the 10.5. Nor does it have the unique 3rd bearing for the pinion support. Basically the pinion is set up similar to a 10/12/14sf or Dana 60/70/80.
