Diesel Burb--big
LongroofJosh
Registered Member
Agua Dulce, Ca.
This is pretty much the begining of what could be a great suburban. Its a 1983 diesel suburban so you dont have to smog it, you can run any engine you want. It has no engine or trans. But it does have:
14 bolt--Drum to drum complete. Has 4.11 gears, detroit locker,diy u-joint guard, bullet proof diff cover, and a new set of 5.38 gears
dana60--disc to disc complete passenger drop with offroad design crossover steering, 4.11 gears, rockcrusher diff cover, psc hydro steering ram. This axle also comes with a new set of 5.38 gears with install kit.
42" tsl's on recentered hummer rims. Has about 75% tread, and balanced with pellets. Also comes with complete full sized spare on recentered hummer rim
I also will throw in a 1985 4x4 burb that I bought for parts. It runs in case you want the engine and trans!!!
This is a roller, just need your engine and trans. Or if your interested I have the 12 valve cummins and nv/5600 trans with 205 transfercase for extra $$
Asking $4000 Call Josh @ 661-435-1827
