rjfguitar said:There is a couple of catches.
1. When you go to sell that diesel pickup on the used market, you are going to get 4-6K of that 8K back, if not even closer to the original 8K. Nearly guaranteed.
Present Value of Money - $8000 today is worth more than $8000 5 years down the road. Tack on finance charges and subtract depreciation on the engine, and its worth even more.
I payed 22.9K for my '01 Ram and could have bought the exact same truck except with a 360 gasser for probably 15-16K.
There really isn't any higher maintenance costs with a diesel vs. a gas engine. People forget two things....
1. They want to compare a 3/4ton Diesel's maintenance cost vs. a 1/2ton gas truck. Then they add in what it costs to do brakes on that bigger truck, heavier tires, and more oil in the drivetrain....and turning it more into a 1/2t vs. 3/4 or 1ton costs.
2. People think oil maintenance is more costly annually than a gas engine. First off, anyone that knows anything about a diesel knows it's dumb to dump oil at a 3K interval with an engine that hold 3 gallons of oil.Since nobody's putting diesels in 1/2ton trucks right now, and Larry's not towing anything, maintenance costs on 1/2ton as apposed to 3/4ton is a legitimate comparison.
Now sure, if you are being a dumb dumb and dumping 3 gallons of oil every 3K than yes it costs a heck of a lot more to change oil in a diesel. But, if you changed oil in a gas engine the same way, you'd be dumping your oil every 1K with your small block.Touche. Oil change people always put a 3000 mile sticker in my truck. I generally run 7500 to 10000 depending on how I'm driving.
Basically it boils down to this. Diesel trucks cost more up front. Period.
Depending on the price of diesel relative to gas, depending on what breaks on it(don't buy a 6.0 liter Furd, ask me how I know), and depending on how long you drive it, you can offset the initial investment with lower operating costs of running it. This is assuming we're talking about a newer vehicle.
From a financial standpoint, I'd saying your better keeping your money on the front end by going with a lower purchase price, then trying to build equity in a highly depceciable asset.
If your buying older (86CUCV for example) everything changes.
That being said. I love my diesel and don't plan on going back to gas anytime soon, even though I could probably save some money.
or the nOOb period
