beags86
Eastbound and Down
You need about two quarts per diff.I have a pump I got to fill the Tcase. But I’ll just buy a few quarts with the nipple. Is synthetic required?
No reason to mess with synthetic if you don't want to.
That would be good but Mobil one is 8 dollars a quart instead of 12. That Permatex is what I use.
Runs cooler. Flows better in cooler temps. Probably not an issue for him.yep that stuff for rtv is the new ticket .
our old rigs use reg oil . if you were using it hard and wanted better you can swap to synthetic .
If your not in a huge hurry I bought 2 quarts for of Mobil 1 for 18 bucks off Amazon.https://www.amazon.com/Valvoline-75...2&sr=1-1-dd5817a1-1ba7-46c2-8996-f96e7b0f409c
Cheaper... will get this and the green permatex
-but whatever is in them may be the original it was filled with in 1982 when it was built maybe..unlikely,but maybe..
