The thread size of the caliper you're using it going to dictate what banjo bolt size which in turn dictates what line you need. Obviously the banjo bolts you have fit the caliper so now you need to see if they fit snugly in the line. If the bolt is loose in the line then they are the wrong lines.
Pretty sure i posted this info on another thread of yours but i'll do it again.
http://www.tsmmfg.com/Brake_Accessories_others.htm#FLEXIBLE%20BRAKE%20HOSES
FLEXIBLE BRAKE HOSES
[FONT=trebuchet ms, Arial, Helvetica]
3702-8 $50.00 pair[/FONT]
[FONT=trebuchet ms, Arial, Helvetica]BRAIDED STLS [/FONT][FONT=trebuchet ms, Arial, Helvetica]8" [/FONT][FONT=trebuchet ms, Arial, Helvetica]AN - 3 3/8 - 24 [/FONT][FONT=trebuchet ms, Arial, Helvetica]M10 X 1.5[/FONT]
3703-8 $50.00 pair[/FONT][FONT=trebuchet ms, Arial, Helvetica]
7/16 - 20 [/FONT]
