Yeah I THINK the '78 Chevette line is 10mm and the calipers and banjo bolts you have are 7/16", so you should just replace the hoses and be fine.
If that were true, the bolt would not go through the line. 10mm is significantly smaller than 7/16. He can either just measure everything (pretty simple) or look at it to tell that it's all the same size. He can't fit the big bolt into the small hole, so no problem there. If it was a small bolt in a big hole, it would be pretty sloppy, and wouldn't appear to be the right fit at all. I doubt he's mixing sizes, cause it's pretty obvious when things don't jive.Yeah I THINK the '78 Chevette line is 10mm and the calipers and banjo bolts you have are 7/16", so you should just replace the hoses and be fine.
I asked for 78 calipers so I assumed they were 7/16 as well. Gonna use 4x4 high link and order up som SS 10mm lines. LOl I got some slightly used 7/16 lines for sale
