grimjaw
cybrfire said:4. Remove drum/hub assembly. (spindle nuts in center of the hub) Spindle nut socket required. Drums can be difficult to remove at times. Special note: there is a funny looking spikey washer between the nuts. It will probably have and end bent into one of the voids in the spindle nut. Pry this out of the nut with a screw driver. ( I like to count how many threads are visible on the spindle for reference later.)
Ok, I am in the middle of this swap and my Spikey Washers look like hell. Does anyone know what this part is really called or have a part number?
Thanks.
