dismantle of a 72
Is it just me or does that Gas tank look odd. And also the filler neck looks like it is on the wrong side.
Is that tank from some other truck and do you have something out of the ordinary planned for the fill tube?
yes the frame is a 74. It is in better shape than the 72.
so you plan on putting a '74 frame under a '72 body?
I was under the impression that there were enough differences in the frames to make that a royal nightmare to pull off. :dunno:
do you have any shots of the 2 frames next to each other? I'd love to see the progress as you work to pull this off.
can you send a link of the build? I would like to see not that it would be how i do it but i am open to suggestions .
some progress and parts
over the weekend the florpan and rocker-boxes are removed and the cross old beam for the florpan on the 4x4 floor is shot so i need one of those i like new parts but if i can get a template i will try and make one and i still dont know how to make small pictures [Imgur](http://i.imgur.com/Z8bxm) [Imgur](http://i.imgur.com/y64Df) [Imgur](http://i.imgur.com/5ZITh) [Imgur](http://i.imgur.com/5Xema) [Imgur](http://i.imgur.com/5HC94) [Imgur](http://i.imgur.com/Xfon5) [Imgur](http://i.imgur.com/7BxS8)
link of what? I'm not sure what you are asking. :dunno:
you'd either have to adjust your camera to take smaller pictures (easiest way for me) or use a program to change the size.
no worries man. I checked out your links. you've made some serious progress. I HATE dealing with rust. have fun! :pimp:
after Easter progress report
I have separated the bed from the fire wall and I am about to fabricate the beam that has the back cab body bushings and floor unless anyone knows of a place that makes them. the drilling out of the spot welds on the new floor is going to make me sad because it is so nice
one more pik
this 1 from passenger side
rust for new
this thing is making may girl friend lonely but i have made progress in my eyes the floor pan is attached to the tow board along with kick panels and a pillar bottoms
I am going to atempe to make the back of the floor pan with the body mounts in it from scratch give me luck
Looking good.
I repaired your photo links for you.
Your hosting site offers "embed codes" off to the side of each photo you can copy and paste into your thread for simplicity. The key is to use the tag around the photo URL to make it visible...
-G
