Just got the 203, has a partial mount on it. Didn't do a thing to it other than drop a nut getting it out of the truck. This is the only one that I have EVER seen.
205 has a crossmember to fit in 70s/80s GM, need to weld in or tabs. Has new bushings. Input face is machined, can be drilled and tapped for whatever pattern you want, just change the input.
Was gonna make a divorced doubler out of the two. $400.
