I used Kert's motor mounts when I did my motor swap in my 89 K5. The fit and finish is first rate. There was no change in height over stock. I would definately recommend DIY4X.
X2!! I don't have those mounts but, everything I've bought from KERT has been very nice,strong and fits very well. I got poly mounts but, I wish I had DIY4X's
if you would be so kind as to get me one piece mount and for an 85 in my sig line. lol ill be giving you a call soon! your help today was great! i appreciate it kert!
allright guys, i got my motor mounts from kert and theyre FUGGIN AWESOME! i also got my trans mount from him too, but what the hell do i do with this extra metal piece?
Is this the right procedure to replace the engine mounts, all you need to do is jack up the engine a little to ge the weight off the mounts, then unbolt, then swap, then tighten, then let the engine rest on its new mounts?
Get all the bolts started that you can before ya tighten anything. That'll help with the install. GM left alot of room for things to be adjusted in there so don't tighten to soon.
