The butt of my K5 is dragging a bit, especially after I shimmed the front, so I'm thinking about giving it a bit more altitude in the rear ... and the easiest way is of course the zero rate.
I have some 2.5x1.5 solid stock, so I could make my own ... but 1.5" seems a bit much. Besides the U-bolts being that much longer, are there any issues at this height?
I also have lots of leftover spring leaves, so I could cut a couple down and make my own bootyfab ZR that way. I was contemplating welding them together, so that don't want to spread apart so much and so they don't look so bootyfab. Is spring steel weldable or is that A Bad Idea?
-- A
-- A
Plus the spring leaves/overloads are cheaper than solid stock
