diy4x beadlocks. **mounted pics and poser flex** pg7
I got thembdown at 12 the other night but that's what usually go down to. What's the lowest I can take them? I was thinking about 8 but I have no idea.
And what's the easiest way to get them centered up? Just time and patience or is there a method to it?
8 should't be a problem. I have always just lined them up best I could when tightening them down. No real trick to it, you may find that tightening in an alternating pattern will help. Let the rotation do the work after that.
You'll find the best pressure for you before too long.
What do you mean let the rotation do the work after that?
Over time they will settle into a spot. Has always worked that way for me.
EDIT: I have no experience with the Air soft bb's in the mix but can only imagine they'd make it all better yet.
Btw, these things are causing too much trouble. Not worrying about losing beads got me... stuck.
If you don't get stuck you'll never know how far is to far, also how much do I need to spend to get the big diy4x stickers.
Looks good
Looks good
I ordered the beadlocks and doors and he threw that in for me. Im not sure how much they are though.
Looks good
When we have them, they are free for the asking. We are currently out right now but I will rectify that shortly.
Time to buy some of your rock rails. But im debating cutting the rockers off and doing 2x4
