readymix said:There you have your answer straight from the man.
[hijack]
Kert. I am going to have to get ahold of you on the phone sometime. I ended up using two of the bolts that came with my Backbone & Wraptor kit in an emergency. I had to help a friend get his Jeep back on the road. I was in too much of a hurry to remember the dimension of the bolts I used.
Hopefully you could tell me what they were when I tell you what parts I have left. I'll run to the store and buy them.
[/hijack]
No problem! So you havne't gotten it installed yet? Need some tips or advice don't hesitate to call!
Bigblzn, give me a hollar anytime.
BKinzey, once you inboard the shocks and have them inside the springs, there is really only one place to put them. Close to the spring. Any further in and you sacrifice available length. Rear of the tube is best to protect the shock. I have seen them on the front and a guard of sorts made for them. This was done when the axle was moved rearward far enough to facilitate complications from upper mount location.
