Okay I was just curious, because there are times when you jam on the brakes they just seem to go soft and then if you slowly apply them they seem to grip harder.
That and all the other ABS systems I have used, the brake pedal pulses and you can hear a humm from the system.
I am guessing the ABS for the 90 and 91 is just a controlled pressure bleed that is varied based on the VSS input for the rate of deacceleration?
Thanks
Tim
