CherryK5
It's a gm10 bolt open carrier. I'm diving straight in. Gonna learn how to set up gears with the old man and I have no idea what to do I want it un assembled and ready when he gets here in the morning.
This!!!Not the knuckles just the axles. Loosen the pinion nut before removing the tires. This makes it easier having someone hold the brakes on.
This!!!
Sucks having to grab a huge crecent wrench or some channel lock pliers to hold the yoke while someone else tries to break the pinion nut without it rotating off of whatever you have the axle setting on.
Yes you can. Easier with that than the physical labor of the wrench.well I was gonna do it on the truck. So couldn't I just go at it with an impact?
You are going to do the re-gear with the axle in the truck? I'd HIGHLY suggest you pull the axle if this is your first rodeo. An impact will work fine if you have a way to stop the gears from spinning, but I prefer to at least break the nut free with something that's not going to hammer away at the gears. Once it's free, spin it off with the impact. I've done a few gear swaps, and I'd pull the axle just so that I wasn't having to deal with crawling around on the ground over and over again each time I had to pull it apart. You want it to be as comfortable as possible so you don't get tired of it and cut corners.well I was gonna do it on the truck. So couldn't I just go at it with an impact?
Yep, the most preferred method to do this job.You are going to do the re-gear with the axle in the truck? I'd HIGHLY suggest you pull the axle if this is your first rodeo. An impact will work fine if you have a way to stop the gears from spinning, but I prefer to at least break the nut free with something that's not going to hammer away at the gears. Once it's free, spin it off with the impact. I've done a few gear swaps, and I'd pull the axle just so that I wasn't having to deal with crawling around on the ground over and over again each time I had to pull it apart. You want it to be as comfortable as possible so you don't get tired of it and cut corners.
Even worse! What happens if it falls? You're dead. Leave the truck to me if you write out a will.well I was going to grab the wrecker and raise the sonbish up to eye level and avoid getting on the ground at all.
I slap the housing on a bench or work table and go from there. Do everything at waist/belly height for comfort.
crawling around under the truck, getting dirty, neck cramps, arm and shoulder cramps.... it's the ONLY way to work for me
Think SAFETY my friend.now what fun is that???crawling around under the truck, getting dirty, neck cramps, arm and shoulder cramps.... it's the ONLY way to work for me
Think SAFETY my friend.![]()
well obviously there would be safety precautions. Like a strap from the rafters. Maybe two. It's not gonna fall. I promise.
I hope this is a joke? Supporting the vehicle from the rafters?
