My rear shaft u-joint at the pinion has some play in it again and not the usual play. The u joint can move back and forth in the yoke. I've been fighting this problem for a while now by just replacing the joint with one from an over the counter parts store. So the drivetrain truck was originally an '84 456/208 with a 10bolt rear and I swapping in a 14bsf. The u joint bolted right in so I just ran with it. Since then every few months to a year I'd have to replace it because of vibration and play. I've finally taken a harder look at it and I noticed that the u-joint itself is fine but it has play in the yoke. See here:
So since the standard u-joints don't seem to fit width wise in the yoke I guess I need a conversion u joint right? Well doing some searching has netted me with the Napa 447 joint which is a SR4-1350 style. However, that part has one side external snap rings and one side internal. The problem is that I need external on both. See here:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Universal-Joint-U-Joint-Combination-Universal/_/R-PUJ447_0010270151
And looking at the chart of u-joints on this website:
http://www.driveshaftspecialist.com/HTML%20Measure/UJ%20ID%20Guide.html
I don't see how I'd need any conversion joint with the measurements from that chart.
What the hell is going on here?
