Last time I used paper gaskets and some indian head gasket shellack. Not a drip.
You may need an air chisel to get the diff cover off later on,and to scrape off the Indian Head Shellac!..but I bet it'll never leak...
I love that stuff,but only for certain things..its about the only stuff that gas wont eat off after it hardens,I have used it on two Q-jets with stripped fuel inlets and they never leaked a drop again (had to delete the internal fuel filter and remember to never attempt to remove the inlet fitting again )..
I used it once on a thermostat housing and the upper hose on a 283 I had in a 67 Impala--two years later I had to use an old wood chisel and mallet to chop the hose away from the housing,and even my bench grinder's wire wheel had a hard time removing that shellac..
Tried using some on a small engine side cover that loved to ooze oil--it cured the leak,but when I had to take it back off a few years later to replace the govenor gear,I had a very hard time getting it apart!..had to use carb cleaner and pry it apart and ended up boogering up the machined surfaces somewhat..
I have coated new brake lines and my fuel injector lines on my diesel where they were getting pitted from rust with the shellac--it seems to be a very good coating that seals out air..have to let it dry a day or so before you can handle the lines though--some I have coated after installing ,using that shoe polish dauber thing that comes attached to the cap on the shellac..
I remember the story a friend told me about his experience with Indian Head Gasket Shellac...he left a bottle of it on his dresser in his room..one sunday morning when he was in a rush to get to church with his wife,they noticed their 5 year old daughter was VERY quiet,and they found her in his room--using the dauber to "polish her shoes",and she had the shellac ALL over her new dress,her fingers,etc..they had to use rubbing alcohol to get most of it off,the rest had to "wear off",which took a few days !--the dress was a total loss..
