Even if it's below zero outside and you are driving 60 mph down the highway, there is simply not enough cold air moving through the engine bay to disipate all of the heat. If you don't believe me, get somebody in a Northern state this winter to disconnect the radiator and see how far they make it down the freeway before the engine blows up.
Air blowing around the outside of a normal car engine (i.e. designed to be water cooled) is simply not an effective way to cool the engine. Water transfers heat way more effectively, and the water is being run a lot closer to the cylinders and other heat sources of a water cooled engine. There is not enough heat transfer area on the outside of the block to get rid of the heat, plus you can't disipate the heat generated away from the outer block surface effectively.
. Did I need it no not really did I need it to have a heater yes.
I run a 4 core radiator and a k&n air filter so it is pulling in the cold air in to the motor also.
So now I think I will go and try a new t stat to see how this plays out.
