I've got 3' 8" length, 21degrees total , running NP205 and 14bff with 1350 yokes.
Need to have some D-shafts built, was thinking a cv shaft, but then I have to rotate the 14b up. Is it really necessary? I'm not into super twisty rock crawling, I only have 2.5" of spring lift. So will a 2 joint shaft spin OK without vibration on the highway and be ok at full droop?
I read a 1350 will go up to 20 degrees max, so mine would be running 10.5 degrees normally. Too much stress?
