Eric M.
I have this problem!
My trucks engine will only fire around 200 Kpa (roughly 30 psi i think).
I'm also having a similar problem with one of my other trucks. I have yet to begin trouble shooting. A few questions for you. Are you sure it's the pump that's not kicking in until 30 PSI and not the injectors not firing?
You might try disconnecting the puel pump lead back at the fuel tank and put a tester on the hot side while someone cranks the engine. If you get power right off the bat, it isn't the fuel pump.
If that's the case, plug the fuel pump back in and pull off the air cleaner lid. Take a look at the injectors while someone cranks. Are you seeing fuel squirting into the throttle body from the get go or does that not happen until you reach 30 psi?
That's as far as I got with my truck. My issue is the injectors not firing. I'm not sure why .... maybe next weekend I'll start looking closer at this problem.
Good Luck,
Post up if you figure it out before I do.
Eric M.
