Eric M.
Here's the deal. I know there has been some discussion here about what the Fuel Pump Oil Pressure switch does. Some say it shuts off the fuel pump when oil pressure drops, the fact is, it does the opposite. It is a back up to the fuel pump relay. As soon as the switch senses 4 psi of oil pressure it closes the fuel pump circuit - in parallel to the fuel pump relay.
Several years ago my battery would randomly die over night. It took a while to trouble shoot, but, I finally found that the Fuel Pump Oil Pressure Switch had a slight short in it. I replaced it.
Now, the ECMB fuse randomly blows and the truck just dies. Again, I trace it to a short circuit in the Fuel Pump Oil Pressure Switch that happens randomly. I disconnect the switch, put a new fuse in and it starts and runs fine, no SES light either.
My question - if this switch is suppose to be a back up to the fuel pump relay and twice now has failed and left me stranded, while the fuel pump relay is still original and working fine, would there be any issues with just leaving it unplugged? Maybe carry a spare fuel pump relay if I really felt I needed a back up?
Am I missing anything this unit does? I've got the shop wiring diagrams and all it seems to do is back up the fuel pump relay circuit.
Thanks,
Eric M.
Thanks,
Eric M.
) then i just swap the connector over and keep going. The fuel pump relay is noly like $10.00, the oil pressure switch is like $35.00 (may be more since these are my cost on the parts).
