Ok it's not all that complex if your wiring needs are similar to mine. Basically I needed a spot that had a ton of 12v switched sources for stuff like my tach, the stereo, a cb, lights, etc.
Some of those items (like the amp, stereo and lights) are using that switched 12v source to fire their own internal relay's that draw power through a heavier guage wire straight from the battery.
While others (such as the cb and the backlight on the tach) are using that switched 12v source as their only source for power... it just depend on what the accessory is and how much power it draws but they all need a switched 12v source...
So this is what I did although there are tons of ways you could accomplish the same thing.
I have two wires coming straight from my battery, one from the positive post and one from the ground... they run all the way across the firewall and come inside the cab near the steering shaft...
Here's where they come inside the cab (you'll want to use a rubber grommet so the insulation on the wires doesn't rub through and short against the truck... it's on my list of stuff to grab next time I'm out and about
Here's where I mounted my block and relay...
The relay will have numbers on it next to the posts...
30 is the main power to the relay so solder on the wire you ran that comes straight from the battery's + terminal...
85 is the ground for the relay so solder on the wire you ran that comes straight from the battery's - terminal...
86 is the trigger... this is what tells the relay to let power from the battery through to the distribution block or to cut it off... I ran a wire from the factory fuse pannel that gets switched on and off with the ignition. So when you put the key in it sends power to this spot on the factory fuse pannel that will now send power to the relay thus opening up the relay and letting power from the battery go to the distribution block...
It's the red wire towards the bottom...
87 is your output(s) (some relay's have two 87's) to the distribution block so solder the main power wire off the block to this terminal on the relay...
That's basically it. So if you do that when you put the key in it'll let power through straight from the battery to the distribution block. If you want you could always run a more complicated distribution block like dyeager and ryoken were talking about so you can set some to be constant and some to be switched but for my needs I don't need any that are constant.
Hopefully that helps get you started... ryoken and dyeager are more technical than I am with terms and such but hopefully you can understand what I did.
