x2 on this . best to options for true testing . and do it with shocks off and measure for correct fitment . and don't use them as limiting / bump stops .
and at the point of driveshaft in that pic if you were real world if hard throttle in 4x4 I be betting that shaft would pop out under axle wrap .
that happened to me. even maxing it out with a fork lift and getting the shaft remade, once I got it out on a trail and throttling up a hill under power, the wrap plus flexing out a little bit was enough to get the shaft to separate. which blew.
I think it would compress more on the ramp because coming down normally both shocks and springs are absorbing the impact. Plus the quicker, sudden motion will be dampened more by the shocks than a slow compression. Assuming we're not talking about some sort of extreme 20ft nose dive or something.
