dodge 60's F&R
muddybuddy
1 ton status
Northern, VA
set of dodge 60's from a '85 D350. will check the gear ratio's when it stops raining. pulled from a running truck in august. its got the factory external selectro hubs. will need a tie-rod (stock one had a slight bend in it so i let a member on here use it for mock up for his 60).
lookin to get $800 for the set
